Reentrant Boolean Array Controlled stopwatch SubVI
I am in the final stages of implementing my program.
Currently I have to overcome two obstacles .
#1 corresponds to the attached VI "My stopwatch"
The round LED starts counting the time and stops it. Problem is even if I turn it off it, the timer keeps counting the seconds when I turn it on again. I want it to accumulate only the time it spent in the on position. How do I do this?
#2 corresponds to the VI "array of time".
I want to use "My stopwatch" as a reentrant subVI in this VI. I want the round LED Boolean array as the control to switch the stopwatch on and off.
Thanks for all your help.
mhaque
Message 1 of 11
(7,413 Views)
Check out the CLD exam example solutions.
One of them for the Car-Wash includes a modification of the "Elapsed timer function" that add a "Pause" Smiley Wink
Message 2 of 11
(7,396 Views)
On a sidenote, have you ever wondered what would happen if you would remove the "equals true?" and wire straight from the terminal to the rest of the code? 😄
(see also)
Message 3 of 11
(7,387 Views)
aaaaaaaaaah so its pointless having the equals to sign.
I was just using someone elses code.
Thanks for clarfification.
mhaque
Message 4 of 11
(7,343 Views)
We just call that WEC.   or Wire Equivalent CodeSmiley Wink
Message 5 of 11
(7,329 Views)
I have managed to modify an existing VI to do what I want i.e. have one start/pause Boolean control for the stop watch.
Criticisms please. The block diagram looks simple enough.
Also I can't quite get it to reset.
Any suggestions.
mhaque
Message 6 of 11
(7,317 Views)
I have managed to make a Boolean Array controlled stopwatch.
It is within a while loop. My question is how do I use this VI as a SubVI? How do I overcome the while loop?
I found this thread
http://forums.ni.com/t5/LabVIEW/handling-while-loop-in-subvi/m-p/1117918
but since I am new to LabVIEW I do not understand how they got over the issue using the VI server reference and Value Change Property node.
They use references but I don't understand how the reference controls tie in with the coding.
Your help is much appreciated.
mhaque
Message 7 of 11
(7,279 Views)
Accepted by topic author mhaque
To use it as a subVI, it is easiest to use globally initialized feedback nodes. Here's a quick example.
(Place both VIs in the same folder, then run CallTimerSubVI)
You are using way too much code. Please rethink what you did! Also study my example.
  • Instead of 24 shift registers use three, containing arrays of 8 elements (or the number of timers you need).
  • You need a resolution of one second, so place a wait inside the loop. There is no need to spin it 10 million times per second, you are just wasting cpu cycles and starving all other programs.
  • One diagram constant of 1000 is sufficient (instead of 16!). You can branch the wire.
  • Why divide both values by 1000, then add? Add first and divide once!
  • Why invert the booleans, just swap the cases if needed?
  • (Even if you really want to invert all booleans, do it once on the array side.)
  • This is a small VI, why maximize to the screen?
  • Note that my code scales well. A few minor changes would allow it to be used with 100 timers. To do the same with your program design would be impossible. 😄
Message 8 of 11
(7,254 Views)
How long did it take you to get this good? Seriously?
It works perfectly! wow!
Message 9 of 11
(7,238 Views)
Shoot I meant to reply to this post instead of
http://forums.ni.com/t5/LabVIEW/Can-LabVIEW-pickup-from-where-it-left-off/m-p/1334910#M542745
Hey altenbach
Where does the VI initialize, i.e from where are the zero filled arrays created.
I want to place a read/write binary file and I am wondering where I should wire it to, to save the timers when I exit the program.
Otherwise the timer starts from 0 which is not what I want.
mhaque
Since you solved both problems I hope this is not too much of an inconvenience.
Message 10 of 11
(7,135 Views)
