Refactor array to table or listbox
I have two input arrays and two output arrays. Need to refactor the input arrays to listbox or table.
How to
  • Display input array in a table or list format where user can enter only numeric values similiar to what array accepts, if the increment and decrement buttons are added to Listbox or table
  • To add a new row
  • Delete a selected row or specify the index and delete the specified row
  • Output array should display the values corresponding the input rows in listbox.
Thanks.
CLD
(2,984 Views)
Here is an example that converts an array into a listbox. I would recommend starting here.
https://decibel.ni.com/content/docs/DOC-6603
(2,948 Views)
I posted some sample code here that shows how you can move a numeric (or any other) control over a specific cell of a table indicator, and then hide the control and update the corresponding cell when the user enters a value. It might be a good starting point for what you want to do.
(2,937 Views)
