Reference to array element
Is it possible to access the contents of an array element without reading/writing the whole array?
I tried with the "Value" property of elements and it works, but it always affects the element in the last position i clicked. I don't know how to choose which element to access. SelStart[] and SelSize[] seem not to work.
Message 1 of 9
(5,265 Views)
No it is not possible
Ton
My LabVIEW Ideas
Message 2 of 9
(5,262 Views)
But i can read/write the last element i clicked... All i need to do is to select another element as if it was clicked. If it can be done with mouse there must be a way to select an element via program... What is that SelStart[] about?
Message 3 of 9
(5,259 Views)
Hi
You could use the "Replace Array Subset" function located in the array palette.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 4 of 9
(5,252 Views)
Hi
Using LV8.0
Message 5 of 9
(5,253 Views)
With some hocus-pocus you can get it done.
Here's how I did it:
  1. Set the number of visible array elements to 1
  2. Set the index (this automatically receives focus now since it's the only one displayed)
  3. Get the information you want from the property nodes (it will now point to the correct element)
  4. Re-set the array to how it was in the beginning (You did remember to save the initial state, right?  😉 )
It's ugly, but it works.
Try disabling panel updates before doing this, and re-enable them after and it doesn't look so bad.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 6 of 9
(5,245 Views)
Yes it works! And it's not too ugly if you plan to use the array only for storing data. I always keep visible elements to 1, and even hide the control.
I did some tests and for very large arrays (10000 or so) it's faster than Replace Array Subset (and the like). But it's much slower for small arrays. Also, it doesn't seem to avoid race conditions as i had hoped, but this one has to be tested better.
Message 7 of 9
(5,230 Views)
The simplest way to read/write a certain position of an array is to use "Array subset" and "Replace array subset" functions . I have attached a simple example containing these LV functions.
I hope this will help you.
Bye
Fabio
Message Edited by Fabio_81 on 11-02-2006 03:46 AM
Fabio M.
NI
Principal Engineer
Message 8 of 9
(5,199 Views)
I know Smiley Indifferent
The topic was not about being "simple" but about being efficient
Message 9 of 9
(5,189 Views)
