Referencing .Net Assemblies
fyi - I still haven't received anything on either email account. If you are still getting a bounce, post your email to see if I can reach you.
Message 11 of 15
(1,006 Views)
I've emailed to both accounts now, zipped as well! If they don't arrive this time I'll post it...
Message 12 of 15
(1,005 Views)
Well, you have found a bug. Unfortunately I am not exactly sure what is going wrong yet. I do know that is works with the current source base (Constellation) but I want to know exactly what the problem is so that I can see if there is a workaround. I'll let you know what I find.
Message 13 of 15
(996 Views)
Keep me posted on any developments with this bug...
Message 14 of 15
(986 Views)
Well, it turns out that the bug is related to the way we sort the GAC and "referenced" assemblies together when displaying the popup list. The problem comes around if any "referenced" assembly is later alphabetically than the last entry in the GAC. In this case the assembly started with Z and the last assembly in my GAC starts with V.
So the workaround is
a. Rename the assembly
b. Sign the "referenced" assembly and put it into the GAC
Of course, if you don't have access to the code, you can create a do-nothing assembly called ZZZZZ or some such and put it into the GAC.
No, it's not pretty, but it should do the trick.
Message 15 of 15
(977 Views)
