Refreshing a multiple plot 3D curve graph
Hello, I have a VI that accepts multiple arrays of sine waves (12) , each containing data of a sine wave, and another one with the sum of all (yes, fourier synthesis). They all end up in a CWGraph3D 3D curve graph. I created an iteration to refresh each plot via plot number input of the 3D curve graph each second. I would l ike to know if there is a way to refresh all plots at the same time.
(3,416 Views)
Hi spyker,
This feature is currently not avaiable using the ActiveX control that the CWGraph3D control uses. However we are always looking to improve our product and you can submit this at the Product Suggestion Center.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,392 Views)
Thank you very much Abhinav, I certainly will.
(3,367 Views)
