Refreshing the user library without restarting?
Does anyone know a way to refresh the user library without restarting Labview?  I've searched the forum and LV help, but I'm not seeing that feature...
Chad
Message 1 of 14
(5,851 Views)
What do mean refresh the user library? What are you trying to do, give us some context.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 14
(5,846 Views)
Accepted by topic author chuggins143
I think if you go Tools >> Advanced >>  Edit Palette Set to cause LabVIEW to reload the palettes.  I've done it once before, I just don't remember exactly if that is what I did.
Message 3 of 14
(5,842 Views)
Recent versions of LV (I believe 8.6 and up) have an Application class method called Palettes.Refresh, which reloads the palettes.
___________________
Try to take over the world!
Message 4 of 14
(5,832 Views)
Sorry, I wasn't clear.... I'm wanting to reload the user library on the fly as I create new subVI's so I can use them without having to reload Labview... which is the only way I've found to have them show up in my UL.  I'm still a pretty green noob here... so, this may be a "basic" feature I havn't used yet.
Thanks!
Chad
Message 5 of 14
(5,816 Views)
Ravens Fan,
Works like a champ!  That's exactly what I was looking for!
Thanks!
C
Message 6 of 14
(5,810 Views)
And what is wrong with the methods suggested? Did you try any of them? I know for a fact that the Refresh Palettes method works.
Edit-posted before you read Ravens response and tried it.
Message 7 of 14
(5,807 Views)
Ok, I've run into a bit of a snafu... I've run the Tools/Advanced/Edit Palette Set... and one time it'll bring up a screen that I can just hit Cancel and the palettes have been updated.  The next time it'll open the Functions and Controls palettes in both screens and I can't close them.  It's like it's in edit mode and there doesn't seem to be any way to exit.  I can run my VI, but I can't even close them.  Any thoughts?
THX
Chad
Message 8 of 14
(5,722 Views)
After much futzing the only way I can get LabView to close is to go into the Win Task Manager and end the LabView process at which time it goes non-responsive and I have to force it to close.  Possible bug?  ..or am I doing something wrong?
C
Message 9 of 14
(5,713 Views)
I've not encountered the behavior you're describing. Is it repeatable? If so, what are the steps you are doing to get the condition to occur? What version of LabVIEW are you using?
Message 10 of 14
(5,706 Views)
