Regarding Clusters
Hi i have a problem and am wondering if anyone can solve this problem and enlighten me at the same time? A picture is attached below but i cant get the right cluster pls advise further. The current problem results in the following error "The type of the source is 1D array of cluster of 3 elements.The type of the sink is cluster of 3 elements."
(2,772 Views)
Accepted by topic author Mac98
If you want to display an array of errors, you can right click on the indicator and choose "Change to Array" (I think that's the wording).
A more common thing to do would instead be to replace the Build Array function with Merge Errors. This will give a single error output, with the first error from top to bottom chosen.
If there are no errors on any of the three wires, it would give a single No Error output.
(2,757 Views)
