Regarding DMA fifo.
My goal is to transfer data to target at its rate. I have the data(array) on the host VI and wants to transfer this data onto the target using a DMA FIFO.
To perform this, i am using two DMA FIFO one at channel 0 which is a host-to- target scoped and the other at channel 1 which is target-to-host scoped.
Depending on the type of the FIFO, i am peforming read and write on those. But i cant find the data on the second FIFO reading at host side.
Can anyone help me in synchronizing the host and the target?
(3,498 Views)
What is your development platform PXI or cRIO
Benoit Séguin
Software Designer
(3,365 Views)
Thanks for reply.
I am using the PCI-5640R boards..
(3,354 Views)
OK give me all information on your project.
Version of LabView.
Details of each target.
Rate of transfert
and if possible an example of your code.
Benoit
Benoit Séguin
Software Designer
(3,341 Views)
