Regarding Labview software version and block used in image
Hi GerdW,
First of all really thakyou for helping me.I want you to ask few question could you please tell me what are the block used after FFT block , and if my input chirp signal descripation are as fallows carrier freq= 1G , IQ=500K, Sampling freq = 10M, Chirp B.W= 10M then what should i keep low pass filter cutoff freq and samplinf freq , also there are lots of window function which should i use, and please tell me the block which is below the dechirp signal and where i can find it in labview.
Thanks for helping me once again.
Message 11 of 14
(432 Views)
Hi Jay,
@jay524 wrote:
  1. what are the block used after FFT block
  2. if my input chirp signal descripation are as fallows carrier freq= 1G , IQ=500K, Sampling freq = 10M, Chirp B.W= 10M then what should i keep low pass filter cutoff freq and samplinf freq
  3. also there are lots of window function which should i use
  4. the block which is below the dechirp signal and where i can find it in labview.
  1. It's an Abs() function...
  2. I don't know. What did you learn at your university about signal theory? Ask your co-students or the teacher!
  3. I don't know. What did you learn about signal theory? What does your teacher recommend?
  4. I don't know. I never used NXG and your image is very blurry...
Message 12 of 14
(428 Views)
I am facing problem regarding one block in Labview NXG can you please tell me which block is below de-chirp signal , i mean the block before  where amplitude response is written in image.
Message 13 of 14
(394 Views)
Hi Jay,
you still don't provide a better image, the current one is quite blurry!
I guess this might be same scaling function, like converting to a dB scale for the amplitude response display. You need a logarithm function and a multiply to calculate dB values…
Message 14 of 14
(388 Views)
