Regarding Vision Acquisition
I am new user in LabVIEW Program.
" You cannot use "IVA Match Pattern Algorithm.vi" recursively.
How can I solve this problem?
Message 1 of 8
(4,245 Views)
quick search of your problem. post if further specific help needed.
Message 2 of 8
(4,239 Views)
I tried many times to solve this problems but it can't work.
I can't run the program.
Thank you for help and your supports will be highly appreciate.
Wasin Pensungnoen
Message 3 of 8
(4,229 Views)
Hi Wasin,
Is it possible for you to post your application? We can help you after we see what's going.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 4 of 8
(4,215 Views)
Accepted by topic author gameafro
Hi Wasin,
Here's a KnowledgeBase you might find helpful:
KB 46EKS80E: Recursion in LabVIEW
 It would be helpful to see how you've coded your VI, how you are using Pattern Match. Are you trying to call on it simultaneously in multiple places?
--Michelle
Message 5 of 8
(4,194 Views)
Thank you for your help and your supports will be highly appreciate.
Wasin Pensungnoen
Message 6 of 8
(4,192 Views)
Is your problem solved? If so, please mark Michelle post as solution to your problem. That will help other people looking for such an issue.
Mathan
Message 7 of 8
(4,180 Views)
I did that.
Thanks for all supports and I' m appreciate  very much.
Wasin Pensungnoen
Message 8 of 8
(4,164 Views)
