Regaurding Tree Operation
Hii Friends,
I am using Tree operation.. In that tree suppose i am having 10 parents in each parent some 3 0r 4 childs will be available....  suppose if i click one Parent i want to know how many childs does the parent have???  how to get it??
(4,263 Views)
Hi Karthikey...,
see the attached example please.
Hope it helps.
Mike
(4,249 Views)
Accepted by topic author Karthikeyan_Mathiyalagan
Thx Mike ur correct yaa i have solved my problem....
(4,245 Views)
Please mark Mike post as solution to your problem if it helped you. You can do so by selecting "Mark as solution" from "Options" menu located at the top right corner of your post.
Mathan
(4,239 Views)
Sorry for the wrong direction. Please mark mike's post as solution and not your own post. Thanks for your understanding.
(4,209 Views)
