Register a .net dll in GAC with installer
Hi everyone,
we have a self-made .NET DLL which is signed and registered in GAC. This DLL is used in an application.
Now I want to deploy my application and on the target computer also register this DLL in GAC.
Is there an option in the LabVIEW installer to do that for me? Or do I have to include e.g. gacutil.exe and run it with command line?
(3,670 Views)
Accepted by topic author Tesla1977
Copying the DLL into the GAC directory can be done by defining an appropriate Destination (assuming that the GAC directory is always the same!). Include the DLL as "Always Included" and put that into the correct Destination.
Running the registration can be done by adding a post-install function (Run executable at end of installation in Advanced tab).
Norbert
Expert: Geometry
(3,659 Views)
Ok, thx.
So I will include the gacutil.exe and run it post install with command line parameters. After that I will delete the dll from the temp install directory.
(3,653 Views)
