Register and numeric constant in labview fpga
Dear member
 I want to Store large numbers of constant  values in FPGA chip using labviewFPGA
after I store the values I want to process them with other variable input
the problem is
which is best method to store these values without using memory and effect on FPGA resource
1-numeric constant??
2-register??
3-constant register ??
I read about numeric constant here http://zone.ni.com/reference/en-XX/help/371599H-01/lvfpga/fpga_sgl_numeric_constant/
he say that it consumes no logic resources on the FPGA. However, if you wire a  numeric constant to a Logical operation, FPGA lookup table resources store the constant value.
Is the comparator operation is considered a logical operation?????
best regeards
Message 1 of 9
(3,954 Views)
Depends how you define a large number.  Are you going to key them all in manually, what data type?  How many 100, 1000, 1000000?
Look at using a memory, right click on the FPGA target -> new memory.  You can use a VI to programmatically set the intial values, then compile them in.
The real question is what the use/purpose of a 'large' number of constant values?
Message 2 of 9
(3,938 Views)
the data type is  14 bits fixed point
the number of constant about 100 numbers
i will process them in same time with other variable in parallel, i has system like SIMD(single instruction multiple data)
 so if i use memory to store them i must read them then i store them in registers them process them.
100 registres i very FPGA consume
best rgeards
Message 3 of 9
(3,924 Views)
Depends on the chasis/FPGA but 100x14bits isn't really all that much space.
Message 4 of 9
(3,918 Views)
My FPGA chip is 500K gate and this 100 *14 bit will be very effect
I use numeric constant its take less space but I note that space will depend on stored value in the numeric constant
is their a magic method to solve the problem!!!
Message 5 of 9
(3,913 Views)
1400 bits will be less than 0.3% of the space if stored in flip flops.  The compiler will optimize as much as possible using the LUT for adders/subtractors.  Your only choice is to use a constant or memory read.
Depending on what your overall goals are, say multiply by a consant, you may be able to handle that on the host side.
Message 6 of 9
(3,905 Views)
0.3% if i use numric constant or registers??
Message 7 of 9
(3,902 Views)
register? Like a shift register?
If it truely is a constant, use a numeric constant then.  The constant will optimize better, a shift register assumes you need read/write capability.
You should post a block diagram of what you have and explain what you are trying to accomplish.
Message 8 of 9
(3,900 Views)
Thank you  for the information share
Its  truly constant
I think the problem solved now and this is my vi you can see in the middle of the vi the numeric constant at the input of the comparators
Message 9 of 9
(3,893 Views)
