Register event callbacks for .net dll
I have been supplied a .dll that was created using .net.  This dll has a "public event MessageHandler NewMessage" for which I would like to register a callback.  I can't seem to find a way to do this in LV 7.1.  What am I missing?
Marisette
(3,164 Views)
Your missing Constellation 🙂
The 7.1 version of LabVIEW does not support .NET event callbacks, but it is going to be supported in the next version.
(3,163 Views)
Now, that LabView 8.0 is finally released, is this issue covered?
(3,097 Views)
Yes, we put full support for .NET events into LV 8. Due to the difference in threading models, you don't use the event structure, however. Instead it is similar to ActiveX, where you register a VI as a callback handler for the event.
(3,076 Views)
