Register for events on a sub-array
I noticed something weird today which may or may not be fixed in nweer LV versions.  This was found in LV 2012 SP1.
If I have a "Register for Events" node with a certain datatype already wired up and I change the input wire it doesn't always update the datatype accordingly.
If I switch between two arrays, it seems to work OK, but if I make a sub-array of the new wire it will only work if previously there was already a wire attached with the same datatype.  Hard to follow?  Here's an image.
If I go through the motions top to bottom, the first attempt to attach the sub-array fails but the second one doesn't.  It seems we need the intermediate "Full" array to propagate the datatype.  I know lots of datatype propagation problems were solved in LV 2013, so maybe this one is already fixed.
(3,272 Views)
Accepted by topic author Intaris
Unless for some unknown reason globals are part of the equation, a quick check seems to indicate it is fine in LV14SP1.
(3,232 Views)
Cool, thought it might be.
(3,170 Views)
