Registration Wizard Running at 100% CPU After LabVIEW Installation
@JoshuaP wrote:
What happens if you rename NI\Shared\NI Network Discovery\niDiscExp.dll to NI\Shared\NI Network Discovery\niDiscExp.bak and then relaunch the wizard?
Renaming the DLL works and gives me the NI Product Registration dialog after loading for 2 to 3 seconds.
This also corrects a similar (identical?) problem that started happening after LV2013 installation, NIUpdateService.exe was running as a scheduled task with options -c -task after LV 2013 installation and the task would hang at 100% CPU.
Both problems appear to be fixed after renaming the dll so it can't be loaded... Also, since I have duplicate files/folders in program files and program files (x86), I renamed the niDiscExp.dll in the (x86) folders since the registration and update services were running from my (x86) folder -- this is just a clarification for anyone else referencing the quoted path above which is not 100% explicit.
Message 11 of 11
(995 Views)
