Registration wizard.exe
Hi, I installed LV 2011 since a few days (Vista 32bit os), But often a process named registration wizard starts by alone eating more or less 50% of cpu. This process is present even when I am not using any software by NI.
Is there any solution? Can I stop any service from services console in order to stop it forever?
Thank you
(6,478 Views)
This has been reported before: http://forums.ni.com/t5/LabVIEW/NI-registration-wizard-at-50-CPU/m-p/1707314
Not sure if the problem was identified. You may need to contact NI Tech Support directly and reference that thread.
(6,472 Views)
