Regular Expressions on strings
How would I go about creating a regular expression in LabVIEW that, say, takes an input of a list of numbers (1, 2, 3, 4, 5) and turns it into an array with the elements [1, 2, 3, 4, 5]? If someone could show me example code, I would be quite grateful.
Thanks.
Using LabVIEW 2009 on Windows Vista
(3,342 Views)
Hi dragon,
to convert the string "1,2,3,4,5" into an array you should use the "spreadsheet string to array" function with a separator of "," Smiley Wink When you need an array of numbers instead of strings (you only wrote "elements") you use "decimal string to number"...
(3,337 Views)
Spreadsheet String to Array should work for conversion to strings or numbers...
Richard
(3,325 Views)
