Regular Labview's VIs unable to execute in lego mindstorm labview module
I'm trying to create a block diagram that using vision aquisition in Labview module to detect my eyeball motion for robot direction control. It's success to run the block diagram.
At the same time, i also using lego mindstorm labview module to create block diagram for the EV3 robot.
But when i interface the two algorithms in the lego module, it can't run the block diagram due to the lego module can't run the other VIs? Because the error state that Mathscript, Vision Aquisition, IMAQ and others, all are not supported to execute.
Any suggestion or other ways to solve this problem?
(2,803 Views)
Did you install Lego Mindstorms software and trying to use LabVIEW VIs in there? Or do you have a regular LabVIEW license with the Lego Mindstorms add on library installed?
Lego Mindstorms is a special version of LabVIEW with restrictions like not being a general development environment. It can only run VIs that are specifically compiled to run for Lego Mindstorms and I suppose only NI has the necessary tools to do that.
Rolf Kalbermatter  My Blog
(2,791 Views)
