Regular expression breaks with \00 in input string
I wrote the following code to illustrate the problem.
Clearly the match should occur in both cases, but it does not occur if \00 is in the input string (within the < > ).
I am not even searching for \00 or \01. This makes the regular expression match rather useless if you have text that contains data in hex form. I am using Labview 8.2. Is this a known bug? Is there a work around?
Tammo
Message Edited by Tammo on 03-06-2008 12:26 PM
(3,092 Views)
There was a brief discussion on this not too long ago.
(3,078 Views)
Doesn't work in 8.2 but does work correctly in 8.5.
Randall Pursley
(3,074 Views)
