Relais controlling through R232
hello,
I got a problem with Relais controlling through R232. I found this file in forum named'Relaiskarte_8Fach_RS232.llb'. When I try to open the file'Relaiskarte 8Fach RS232 Open-Close Channel.vi', there is a ctl file named"com1_12port.ctl" which could not be found. then the whole program does not funktion either.
it would be very nice if someone could help me out here.
best wishes.
Weichang
(3,117 Views)
Hi!
I wanted to control relays with the serial port to, and find it is very much easier with the parallel port... pin 2 - 9 are 0-5v ttl output and pin 18-25 are associated gnd.
I hope that will help you.
Yann
Yann Falevoz
R&D Engineer, Instrumentation & Software
(3,110 Views)
Hi!
Yann
Yann Falevoz
(3,110 Views)
problem solved. just delete that port and create a new one, then it works.
thanks very much.
(3,098 Views)
