Relative min and max of Waveform
I am wondering if I could get some help trying to capture a waveform measurement in LabView using an analog input.  I attached a picture of the waveform I'm trying to capture and the values I'm trying to read.  Would this type of measurement be possible in LabView
(2,753 Views)
What rate is the waveform oscillating?  What rate do you plan to sample at?
As far as measuring those value, it is a matter of finding the right ranges to sample at.  What I have done for something somewhat simlar was to make a moving RMS on the entire waveform.  This should result in something like a square wave.  From there, you can look for the edges.  That will give you the ranges to do your amplitude calculations on the original waveform.
GCentral
(2,741 Views)
The main frequency is approx. 20.5kHz and that frequency is modulated at approx. 17Hz.  I am currently sampling at 200k samples/sec
(2,729 Views)
Alright.  A standard DAQ card should be able to do that.  If you aren't sure how to use a DAQ card and DAQmx, look in the LabVIEW examples.  Then try the analysis, which I described above.
GCentral
(2,719 Views)
