Relative path in exe
I am running Labview 2011 p1. Within my project I load classes dynamically out of my exe file for quite a while now.
Yesterday, although I haven't changed anything in the part of the code, it stopped working showing me the error 7. It took me quite a while to figure out the reason:
My project resides in c:\users\username\Desktop\abc\xyz
The source of the class I load resides in c:\users\username\Desktop\abc\xyz\classes\class
Up to now I always loaded the class using the following path c:\..\executable.exe\classes\class\class.lvclass
But now I need to load the class with the following path: c:\..\executable.exe\Desktop\abc\xyz\classes\class\class.lvclass
I am not aware of any change I made nor is it clear to me why the new relative path is chosen.
Any clues?
(3,579 Views)
Hi
please refer to the knowledge base article:
http://digital.ni.com/public.nsf/allkb/EEE8A5650DAC28558625762F0070A384
so, it should have always worked with the new path you are using " c:\..\executable.exe\Desktop\abc\xyz\classes\class\class.lvclass".
i am not sure how it worked with the "c:\..\executable.exe\classes\class\class.lvclass".
Regards
Freelance_LV
TestAutomation Consultant
(3,558 Views)
Hi
thanks for the quick answer. Unfortunately I still don't understand it. Maybe you could give me some further explanation.
In the example
C:\AAA\Main.vi
C:\BBB\Second.vi
translates to
C:\Application.exe\AAA\Main.vi
C:\Application.exe\BBB\Second.vi
As far as I understand it LV uses a relative path to a common folder. In our case it would be C:\
But what happens in the following case?
C:\YYY\ZZZ\AAA\Main.vi
C:\YYY\ZZZ\BBB\Second.vi
Up to now I thought it would still translate to
However, in my case it seems to translate to
C:\Application.exe\ZZZ\AAA\Main.vi
C:\Application.exe\ZZZ\BBB\Second.vi
But if that is the case, why doesn't it translate to
C:\Application.exe\YYY\ZZZ\AAA\Main.vi
C:\Application.exe\YYY\ZZZ\BBB\Second.vi
or in my case e.g. to
c:\..\executable.exe\Users\username\Desktop\abc\xyz\classes\class\class.lvclass
It seems rather arbitrary to me.
(3,547 Views)
