Relative time on waveform chart
How do I set a waveform chart with relative time.. from 6am to 6pm? I set the minimum and maximum (by.. right click- properties settings) to 21600 and 64800. I set the offset value to 21600. But when I run, there is no synchronization. If I run the vi at say 10am, shouldn't the y value be at 10am point on the chart? or is it that I have to run at 6am itself?
Message 1 of 19
(6,537 Views)
What data are you sending to the chart?  Is it a waveform, scalars, or an array?  If it is a waveform, make sure the t0 is set appropriately in it.  If it is scalars or arrays, make sure the scale factors for the X axis, multiplier and offset, are set correctly.
Message 2 of 19
(6,522 Views)
And did you set the x axis property for relative time?
Message 3 of 19
(6,519 Views)
Hi ,
I am sending scalars to the chart. Yes, I have set x- axis offset and multiplier. Offset is 21600 and multiplier is 0.5 (By the way multiplier is the interval between samples ryt?)
@Dennis  Yes, I have set x axis property for relative time.
Message 4 of 19
(6,509 Views)
No.  Offset is the time that your first data point occurred.
You want to set the X min of your X-scale to be 21600 seconds, but the offset of the data should be the time in seconds that it occurred.  Setting the offset to 21600 is why your first datapoint is showing up at 6 am rather 10 am.
Multiplier is the scaling of the data.  So if you are getting 2 readings per second, then your multiplier would be 0.5.  If you are getting a reading every 5 seconds, then your multiplier is 5.
Message 5 of 19
(6,500 Views)
Hi Raven,
So you mean I should hit run at 6am? Can I programmatically set the vi to run at 6am? .. and what happens after 6pm? Will the results not be displayed on the chart?
Message 6 of 19
(6,480 Views)
Hi kdm,
if you want to have x axis as time you should use graphs. They will make your life easier in the end…
Either use waveforms (instead of scalars), they come with timestamp data embedded. Or use an XY graph and provide a timestamp for each sample.
Charts may work, but you will have a lot of extra effort:
- Charts have a fixed history. You need to provide a history size so all your data between 6AM and 6PM can be buffered internally.
- Charts support only fixed sample rates (when used with scalars). When you don't provide samples with a fixed samplerate you will not show correct plots…
- Using scalars you cannot plot Y vs X value. The chart will always use the index number of the point to calculate it's x value…
Advantages of graphs:
- They support real timestamps for x axis.
- The buffer is only limited by your programming.
- They offer more capabilities regarding x axis manipulation.
Message 7 of 19
(6,476 Views)
Hi Gerd,
Thanks for the information. I will experiment with XY graphs.
How do I programmatically start the VI at 6am and stop at 6pm? And what do you mean by "The buffer is only limited by your programming." Is it possible to make it run for months? Don't I have to set the buffer length?
Message 8 of 19
(6,470 Views)
Hi kdm,
I wouldn't trust on a Windows PC for month, but in general: yes.
I mean: The buffer can be as big as you program it to be…
Sure, but it's up to you. And you can change it at runtime (in contrast to using a chart with a fixed buffer size)!
Message 9 of 19
(6,461 Views)
If I have set my relative time as 6am to 6pm, and I refresh chart/graph at 6pm, the maximum(x scale ) changes and data still keeps plotting even though it is not 6am yet.. Why?
Message 10 of 19
(6,404 Views)
