Relay control via time
Accepted by topic author Chowdhury_Milon
Hi Milon,
I want the relay off permanently after 5 sec.
as has been told before:
open the relay AFTER the loop by sending a FALSE with an additional Write function!
Message 11 of 13
(1,334 Views)
Check the input nodes Elapsed Timer, You can find Auto Reset by default it will be true make it false, if you dont want second iteration. you can make relay off in the False case and come out of the loop.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 12 of 13
(1,329 Views)
Message 13 of 13
(1,324 Views)
