Relay timing
Hey guys,
I have  build a small program to control 8 relays on a conrad relay card.
Individual relays are controlled by sending commands with 19200 Baud without handshake signals, 8 data bits, without parity bit and with one stop bit.
The programs shown works perfectly if individual relays need to switched on/off.
Now i would like to add a timing function i.e. controlling the timing of individual relays based on user input.
Any suggestions on how to go about it would be appreciated.
(4,119 Views)
Try to refactor your code into State Machine:
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
It will help you to manage timing properly 🙂
Marcin
Think Dataflow - blog.mtapp.tech
(4,095 Views)
Use State Machine Architecture for your application and for controlling Timing you can use Elapsed Timer.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,092 Views)
Hi Zezendapus,
Could you please upload the vi for Labview 2012? I have the same issue and would like to give it a look but with the old version of labview that I have.
Thaks in advance.
Vanessa
(3,383 Views)
