Reliable USB hubs
@RavensFan wrote:
I've used quite a few of these and never had a problem.
http://www.iogear.com/product/GUC232A/
I use the same ones with good luck as well.
Also like the SiLabs CP2102 USB-UARTs, but that's more of a design-a-product part.
As far as hubs go, Startech's got some that I've had really good luck with:
http://www.startech.com/Cards-Adapters/USB-2/Hub/Mountable-4-Port-Rugged-Industrial-USB-Hub~ST4200US...
Will need a power supply with it, digikey/allied/mouser/mcmaster all have 12v-2a plug-in supplies that work.
Message 11 of 15
(1,162 Views)
I will look into those, i am actually running an SIlabs USB in this application and have not seen a failure in that one, but that converter is built into another device.
-Matt
Message 12 of 15
(1,150 Views)
Does it use a Prolific or FTDI chipset?
Unless I'm completely mistaken, it uses the FTDI chipset.
From what I've seen on the forums, most people have had more success with the FTDI chipset than the Prolific.  Though I think I've seen a few messages where people swore they had problems with the FTDI and not the Prolific.
Message 13 of 15
(1,138 Views)
I have used EasySYNC devices (FTDI chipset) with no problems.
Lynn
Message 14 of 15
(1,130 Views)
Seems like it is pretty definitive that the FTDI chipset is the best option.  I just picked up two, but the companys website is down and thats where the drivers are at.  So hopefully they fix that soon and im gonna run this over the weekend and see if i have any issues.
-Matt
Message 15 of 15
(1,124 Views)
