“Reload I/O Devices ” and enter “Op mode” in State Machine using “TwinCAT ADS DLL/OCX"
TwinCAT(2.10.0) and LabView(8.5). I have to check the EtherCAT communication between TwinCAT and our Drive.In order to do it I must enter “OP mode”. There are two questions:
How can I “Reload I/O Devices (F4)” using “TwinCAT ADS DLL/OCX”?How can I enter “Op mode” in State Machine using “TwinCAT ADS DLL/OCX”?
Thanks!
Igor.
(5,559 Views)
Hi Igor,
I am not familiar with the TwinCAT PLC. Can you explain how you are using it in your setup?
I am a bit confused with your questions. What do you mean by "reload"? Can you provide a screenshot?
thanks
Flash
(5,525 Views)
Accepted by topic author IgorA
I solved my problem.
It’s possible to enter “Op-mode” immediately after “Reload I/O Devices” by changing the number of properties in TwinCAT program.
(I/O Configuration -> I/O Devices -> Device1(EtherCAT) --à EtherCAT -> Advanced Settings…)
To open/close the TwinCAT and press ‘F4’ (“Reload I/O Devices”) is no problem to perform with vbs-files (Visual Basic Scripts).
So, the sequence of the test is:
1. Open TwinCAT program and press ‘F4’ (run the vbs-file from command line)
2. Perform the communication Test:
    a. Change the value in the Drive(our device) and see the same value in TwinCAT (Drive 1 -> Inputs)
    b. Change the value in TwinCAT (Drive 1 -> Outputs) and see the same value in the Drive
3. Close TwinCAT program (run the vbs-file from command line)
All these steps are done in LabView.
Please don’t hesitate to ask me for code and vbs-files (in you need).
Thanks.
 Igor.
(5,512 Views)
Hi IgorA,
maybe it is too late, but can you give me some help to make what you had done?
Thank you very much in advances
Mauro
(4,838 Views)
