Remainder quotient vi - Did i find abug or am I missing something
Can anyone confirm if the remainder quotient vi works well in Labview 2015 64-bit. For example When I divide 2 by 1, I expect my quotient to be 2 and my remainder zero. Apparently it behaves the reverse. Quotient is zero and remainder is 2???
[BADGE NAME]
(3,287 Views)
Are you sure you are checking properly?
Can you post VI/Snippet?Example_VI.png
uday
(3,269 Views)
Are you expecting the quotient to be the top output from the function, because it is not.
aputman
(3,240 Views)
attach the vi which you have tried because its works fine for me
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,213 Views)
