Remembering Previous State in Array
It appears I can't wire an array back to itself so it can recall it's
previous
state.
I'm trying to read and record a multimeter measurement for 7 different
values
and place the output into an array that corresponds to one of 7 different
buttons.
I'd like the array to remember it's previous state for the buttons that
aren't
being pressed.
Here's a link to the vi of what I'm basically trying to get at:
http://members.fortunecity.com/pongclub/MultiMeterSwitchArray.vi
Any ideas for solving this problem will be appreciated.
--Rob
http://members.aol.com/ttoutpost1
Message 1 of 8
(5,316 Views)
I didn't look at your VI, but a good way to use outputs for its own input is with shift registers in a while loop - then the output data can be used as needed and wherever. Also, I often use the "Write to File" VI (array or characters) and read that .txt file back in where needed using the Read from File VI. Hope this gets you closer...
Message 2 of 8
(5,316 Views)
The shift registers are exactly what I needed to use.
Message 5 of 8
(5,316 Views)
If i understood you well, i attached a vi that will do that (your link seems to be dead, so i didn't check the example). If not, just ask.
Hope this helps
Message 3 of 8
(5,316 Views)
Cool. That's exactly what I needed. I've attached my previous vi with the shift register included.
Message 4 of 8
(5,316 Views)
Robert,
I'm coming in a little late, so if you already have a solution, please
disregard.
If I understand your problem correctly, you are asking for two things.
First, you need to select one out of multiple array positions to store a
value. Second, you want to replace an array element at that indexed
position.
It sounds like a radio button array would work for the first part. For the
second part, there is a Replace Array Element VI that will do this for you.
I'm sending the VI to you in a separate email.
Mike
Message 6 of 8
(5,316 Views)
can you post that vi here
Message 7 of 8
(3,280 Views)
Hi Harish,
Do you really expect an useful answer after 22 years?
What's wrong with the VI posted back then?
Message 8 of 8
(3,274 Views)
