Reminder: This forum is for LabVIEW Real-Time.
I have seen quite a few posts in this forum that have nothing to do with LabVIEW Real-Time. "What is LabVIEW Real-Time," you might ask. It is actually a module that installs on top of LabVIEW for Windows, and allows you to download VIs to embedded computers that run a Real-Time Operating System, so your programs run deterministically. Check out the FAQ.
Many questions posted here are actually regular LabVIEW questions, and will find a larger audience, and probably quicker responses, if they are posted in the LabVIEW Gen
eral
forum.
Also, many questions are actually DAQ questions, which will find a larger audience in the Measurement Hardware forum.
Happy Programming!
Chad H
Applications Engineering
http://www.ni.com/ask
(3,282 Views)
This might be slightly changed since NI released new LabVIEW Modules like the PDA and the FPGA Modules. Those questions related to LV PDA and FPGA can find here a good community for answers and hints.
Still LabVIEW General questions and hardware questions should be better placed in other forums.
Happy wiring!
Roli
(3,281 Views)
Hi
I am working for active noise control inside a duct, I am using real time application with sampling rate 10 000, max. frequency 1500 Hz and 2 outputs.
I had  a DAQ card 6221 M series is this sufficient for this application or I might use another.
Waleed
(2,952 Views)
Hi Waleed,
Are you actually using LabVIEW Real-Time, or are you just trying to make your application fast.  If you are not using the LabVIEW real-time module, then you will want to post on the DAQ forum.
Brian K.
(2,896 Views)
