Remote Front Panel Missing IMAQ Image Display in Internet Explorer
Hello!
I have an application developed using NI Vision Development Module. One of the functions is web panel to check the results in internet browser. So, I had to create html page according this guides:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LrSSAU&l
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3SaCAI&l=en-US
In most remote PC everything works fine (I can access front panel and use full functionality), but I faced with a problem only on several machines where I can access to front panel but can't use IMAQ Image Display - I have black field without any functions instead of Image control. It seems that somethings blocks some components in IE.
So, I have already checked: MS Silverlight, LV ActiveX and IMAQ ActiveX plugins in Internet Explorer. Everything the same like on others machines.
Also I tried this guide:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019M9WSAU&l
LabVIEW version: LV18SP1 x64
OS Host: Windows 10
OS Client: Windows 10
Internet Explorer Version: 11.973.17763
Network: Local
Hope for any suggestions!
Thanks in advance!
(2,734 Views)
Accepted by topic author goodbooroondook
Problem was solved.
I had to rebuild Installer of Web Interface components in LabVIEWx32 and reinstall all itmes on the test machine.
Requirement components in installer:
MS Silverlight
NI LabVIEW RunTime (including NI ActiveX Container, NI Web Server)
NI Vision Common Resources
NI Vision RunTime
Thanks.
(2,572 Views)
are you install labview too in PC target?
(1,091 Views)
