Remote LCD Screen
I have a central PC controlling several remote testrigs. I would like to have a display local to each test rig that displays a summary of the test (just a few important parameters). I would like to send the information from the host PC via Ethernet.
Has anybody come across such a display?
Message 1 of 8
(4,078 Views)
there're several possible solutions. I would recommend a rugged Touch-Panel-PC with a small LabVIEW application on it. There a several possible suppliers fot that.
Tyler.
Certified LabVIEW Architect
Message 2 of 8
(4,073 Views)
Thanks for the reply, cost (as always) is a big consideration and a rugged touch panel would probably be a bit of an overkill. The screen is purely for indication (no control/input required locally at the test rig).
Message 3 of 8
(4,065 Views)
Mmh,
I understand. I also see that this proposed solution is not the most cost effective. But currently I only see the possibility to use a Panel-PC with a LabVIEW application or a separate panel. Some time ago we used a remote panel from Sütron. This could be configured via a serial protocol, in the mean-time there could be an Ethernet-based panel available. If no Ethernet is available there's still the possiblity to use a Ethernet-Serial-Gateway.
http://www.suetron.de
Sorry, I don't know nothing further. Hope this helps a bit.
Tyler.
Message 4 of 8
(4,058 Views)
Depending on the situation (how industrially rugged does this need to be?) you might be able to get away with a cheapo android tablet and the data dashboard app?
Message 5 of 8
(4,039 Views)
Thanks for the suggestion Phil. I have never used the data dashboard, can it handle multiple devices (The PC will be controlling 12 rigs and I will need 12 displays). It does not have to be rugged/industrial.
Message 6 of 8
(4,036 Views)
I don't have a work related application for it at the moment so have not had a chance to have a propper play with it yet.
My suggestion was only based on all the NI propaganda that I have seen on the subject recently.
From what I have read, I wouldnt imagine 12 rigs worth of indicators to be a problem. There seems to be plenty on the subject when asking Google.
Message 7 of 8
(4,030 Views)
Yes - the Data dashboard does allow you to add multiple systems from the same dashboard and you can easily select between them.
Have a look at the video below, a demonstration of the App.
LabVIEW Data Dashboard on iOS and Android
Kind Regards,
__________________________
Aidan H
National Instruments UK & Ireland
Message 8 of 8
(3,962 Views)
