Remote Monitoring Latest Best Practice Architecture
Hi guys,
I've developed very few remote monitoring systems in the past. One of them was using a PXI RT and the rest are cRIO. The approach and architecture were based from some of the things I've read from ni.com and this forum. In the process, there were much difficulties and some extensive troubleshooting exercises that I need to do. The results, while the system work and meet the user's requirements, it didn't meet my own expectation. I was hoping that the system can be expanded (adding more cRIO or PXI) with much ease and little or no re-programming effort. Anyway, 2-3 years have passed and opportunities with similar requirements has emerged. So, I would like to get started to think about the architecture at an early stage (ie. now).
In my past systems, I've used Shared Variables (SV) a lot - and it gave much much headache too. Some of the troubles I had were:
1. I can't decide whether to lump all SV in one library and host them in one system, or to separate them into various libraries and systems... neither do I know what's the best approach, as I've read too many 'suggestions' and 'advices',
2. Some of the SV are from custom control and the control is type-def. When running the VI in RT with these SV in development platform, everything works smoothly but when I compiled and deploy, the program didn't run. After extensive troubleshooting, I found out that this had something to do with these SV - because when I removed the type-def from the custom controls and recreate my SV, everything worked fine. I suspect this may have something to do with how I deploy but after I tried several approach, the problem still persist.
3. The best and most common of all is unstable connectivity - it work today but that doesn't guarantee it will work tomorrow. When the host PC changes, the same problems resurfaced again. I read somewhere that I need to read or interface with the .alias file but this work some times and other times, the same problem persist.
Attached is the most common architecture that I've used. I would like to move away from SV as much as possible. If the application is 1:1, there's no problem as I can easily use TCP/IP & Network Stream. However, my doubts and headache comes when the RT:Host communication is either 1:N, N:N or N:1. I've read in ni.com and found out that there are various new approach to this, such as AMC (derivated from UDP), Web Services (or was it HTTP).
I really appreciate it if you guys share your thoughts and advices here, please?
Shazlan
Message 1 of 1
(3,026 Views)
