Remote Monitoring
Can LabView be use as SCADA for remote monitoring of Gen sets with various type of AMF and in different locations.
Message 1 of 8
(4,764 Views)
What does AMF mean?
The answer is yes.  You should also look at the DSC module as it is meant to give you SCADA type functionality.
Message 2 of 8
(4,762 Views)
Auto Mains Failure
Message 3 of 8
(4,754 Views)
DSC you mean DeepSeaController?
What I want to do is to connect module (or controller) on DG's to internet then have a laptop with a software on to connect to this DG's to view the controllers/module.
Its the software i am looking for.
Message 4 of 8
(4,753 Views)
Message 5 of 8
(4,732 Views)
RavensFan,
Guess no hardwares needed?
Message 6 of 8
(4,725 Views)
You already said you have hardware such as "AMF"  and controllers.
If you need more hardware, then you'll have to tell more about the signals you are trying to measure and what other sensors you have.
Message 7 of 8
(4,717 Views)
Yes, thanks so much. I will get back to you.
Message 8 of 8
(4,713 Views)
