Remote Panel windows report LabView 2009 f2
 I'm trying to make this simple logic, but every time that I run this vi and connect to the web server a report message from windows appears and the Labview close.
 I need to know when someone connect to the Webserver, there is another way to do it?
PSÇ Using Labview 2009 patch f2
Renan Perceguetti
(3,322 Views)
Hola.
        Sigue dos link para su consulta
         Link:http://decibel.ni.com/content/docs/DOC-7746
                http://zone.ni.com/devzone/cda/tut/p/id/4791
Diogo.
Message Edited by Diogo Ap. on 11-27-2009 07:23 AM
Diogo Aparecido
Applications Engineer II
National Instruments Brazil
(3,289 Views)
The remote panel function and the web server are working well, but when the logic above is inserted, labview chashes. I realized that, while there is no screen change, it works normally, but when I change it, all goes down. I'm changing screens with subpanel.
(3,276 Views)
Hello Renan, how are you doing?
I´ve done some test on my computer, and in the Open VI Reference in the Run VI, could you create a constant for the options input and make it a numeric of 8. Also could you make each of the subVI's called reentrant (probably the most important fix)! They are default non-reentrant. In my PC works fine. Could you test in your application?
Best Regards
Cesar Federice
Application Engineer
(3,177 Views)
