Remote Pannels
I cannot get the embedded remote pannel to work on my server. It tells me 'server dose not support remote pannals.
I tryed a monitor in the web page but I have to click refreash to update the pannel. Its my understanding that it would update automatically.
I'm using Windows 2000. Please e-mail me with and help kepki2003@yahoo.com
(2,842 Views)
Are you sure that you're using the LabVIEW web server and not a different one? As I said in one of your other postings, have you tried to get everthing working locally first? From the Options menu of LabVIEW, enable the web server (Web Server: Configuration), select Allow Viewing and Controlling (Web Server: Browser Access) with a * in the access list, and select Allow Access (Web Server: Visible VIs) with *.*. Then open the VI you want to control remotely. From the Tools menu, select the Web Publishing Tool. For Viewing Options, select Embedded and then click the Save to Disk button. Save it locally to the LabVIEW 6.1\www folder. when the Document URL window pops up, click the Connect button. It will take a short time to download the panel and then you
should be able to request remote control. If something doesn't work, explain in detail when exactly you get any kind of error message and what it is.
(2,842 Views)
