Remote/Web panel text/colors
I have a remote panel loaded using Internet Explorer for control of an sbRIO. The system turns on and off quite a bit so when the web panel first loads, you see something along the lines of web panel loading, downloading 0.0%.. I does load, but my question is regarding the loading text and background colors. I know how to change the HTML color scheme, but what about the white background inside the actual web panel (in the <embed> code in HTML). I'd also like to change the text itself if possible..
I want to do it as it would look alot better if maybe there were a AJAX loading spinner when it is loading up (rather than the text), and have a black background since my VI being loading has a solid black background..
Thanks!
(3,363 Views)
Accepted by topic author dmaslach
The 'panel' is actually the LabVIEW Remote Front Panel plugin (so it's like embedding some executable code rather than displaying/generating web content) - I don't think you have any control over the appearance of it outside of the configuration in the <embed> tags.
If you want to something more advanced than that...you would probably need to look at other solutions (like WebSockets! 🙂 )
(blog)
(3,359 Views)
Dang, i was hoping there was some other file I could mess with to change it.. I may have to get creative with some javascript... these little things always really bug me
(3,352 Views)
