Remote access in LabVIEW
Recently, I received the Compact DAQ that I bought.  The CDAQ is connected to a remote computer that does not have labview, but remote system does have MAX and LV run time engine.  I am trying to access that remote CDAQ on my local machine through LabVIEW, but it doesn't work.
For my GPIB and serial instrument on the remote sysem, I can access them through VISA server.  I can see all these instrument on my local machine, except for the CDAQ.  I thought I could see the CDAQ on my local machine through VISA server, similar to how I see the GPIB and serial instrument on my remote machine.  I guess this is not the case.
All I want to do is to access my CDAQ that is connected to a remote computer on my local machine.  What are the different ways to achieve this?
Kudos and Accepted as Solution are welcome!
(3,086 Views)
Can you give me a little more information on your setup. Which cDAQ chassis is in question?
If I understand you correctly, you want to connect to the cDAQ using another computer, do you have DAQmx installed on the remote computer. Again, how is the cDAQ connected to your system?
A. Zaatari
(3,056 Views)
