Remote database acces
I have the following configuration:
- one master PC, running LabVIEW DSC 6.0, profibus network, building a database with signals received from field equipment.
- the second PC, running LabVIEW DSC 6.0, networked with the first PC, must read the database from first PC and generate some reports and graphics.
When I try to open database from the second PC, I receive the next message: "Error!!! Browse returned with an error. I suggest chossing Select... from the File menu to choose a different tag list or .scf file."
What is the problem? Some configuration or update problem?
Many thanks.
Vlad Dragomir
Software engineer
AXT 2000
(3,710 Views)
Do you have LabVIEW DSC 6.0.2 or just 6.0 with the upgrade. If you have 6.0.2, there is an update:
ftp://ftp.ni.com/support/labview/labviewdsc/fixes/6.0.2
Read the readme.txt and follow its directions. Please advise if you do not have labview 6.0.2
Thanks.
(3,709 Views)
