Remote debugging an executable with dynamically loaded subpanel VIs
All,
A colleague of mine is attempting to perform remote debugging of an executable he has inherited. It includes subpanels that show dynamically loaded VIs. When connecting with the remote debugger, the main executable shows fine, but the dynamically loaded VIs are not showing their front panels. They appear ok on the remote PC where the executable is running, but they don't appear on his laptop from where he is running the debugger.
I don't have access to LabVIEW currently, and he cannot get this to work, so I thought I'd ask the community this generic question:
"Is it possible to remotely debug a LabVIEW executable with subpanels that show dynamically loaded subVIs?"
Technically he can see and probe the block diagram of the main executable, but the subpanels are blank where the dynamcally loaded subVI front panel should show, making it impossible to interact with the program.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,696 Views)
Hi Thoric,
We're currently aware of this issue, and are working to fix it for a future revision of LabVIEW.
Kind regards,
Josh E
National Instruments UK & Ireland
(3,666 Views)
Thanks Josh. Does this issue have a CAR number I can tag?
(3,657 Views)
Hi Thoric,
Sure, it's CAR#140262
Kind regards,
Josh E
(3,650 Views)
