Remote devive access and acquiring signals from a different PC in the same LAN
Well, I'm still interested in knowing if the way to see the DAQ channels from one PC to another located in the same LAN is the Remote device acess RDA?
If the answer is yes I would appreciate the information from sombody who has done it.
(2,497 Views)
Please don't create another question. I answered you to a previous one that is the same than this. Here is also the response.
the only easy way in order to do that is to use RDA ( Remote Device Access ). This is a component that is installed when you install NI-DAQ. Currently, RDA is only supported by Traditional NI-DAQ. So, if you have programmed your application using NI-DAQmx, it might be more dificult because you will have to use networking communication VIs as Datasocket,TCP/IP, ....
Here you have a link about RDA. There, there is a link to an Application Note called Networking Two PCs for Remote Data Acquisition
http://digital.ni.com/public.nsf/websearch/5CC9792C6CD4A34C862565BC0072D5DF?OpenDocument
I hope this helps.
Regards
crisR
(2,490 Views)
