Remote display and control on separate computer
Is it possible to provide remote display and control of a LabVIEW application from a separate computer under LabVIEW 5.1.1?  If so, what is the best method to achieve this?
(2,743 Views)
You could accomplish this very easily using remote panels, which were introduced in LabVIEW 6.1, so you may want to consider upgrading. While it may be possible to do remote control in LabVIEW 5.1, the functionality is certainly not built-in, which means that it would most likely be a pretty involved task if it were even possible at all.
Kind Regards,
E. Sulzer
(2,725 Views)
