Remote panel doenst load..
Hi ,
i am working with remote panels but i cant get a connection with my own pc to the testpc. When i connect with another PC with only the LV runtime installled no problem occures. I also tried disabeling my firewall on WinXP SP2, doenst work. network condition on both PCs are the same. I get the messages loading 0% but this doenst changes.
B Bakels
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(2,587 Views)
Can you give us a bit more information, like version numbers, does your local machine show up in the Remote Panel Connection Manager, are you using any access rights in the web server, etc?
It looks like your Network Connection is ok, you can connect to the Remote panel server.
Have you tried to (re)install the RTE on your local system?
Karsten
(2,566 Views)
