Remote panel feature supports Apple ipad
Whether LABview remote panel feature supports in the newly released apple i pad? . If yes, Is there any special setting need to be done?
(5,835 Views)
You should read this thread.
If you've ever used remote panels, you should know that in order for them to work, you need to install the LabVIEW runtime. That is currently not possible on any of the Apple products, afaik.
(5,814 Views)
Is NI working to introduce LABview for tablets?
As the smart phones are trying to take over notebooks, although it will take time but are there any engineering softwares for Apple, HTC or Nokia products?
(5,116 Views)
You can use the remote panels feature from any mobile, IPhone, IPad, Android etc. All you need is a simple web server application. If interested you can contact me on colinrebello@hotmail.com
(4,176 Views)
Have a look on ARCALE REMOTE PANEL (ARP). It's coming soon !!! Take the control of any NI LabVIEW application with your iPad. Arcale Remote Panel ( ARP ) provides a simple, multi-client , multi-window, multi-control solution without front panel customization limitation. https://www.youtube.com/watch?v=PqlJUBua0Ww
(3,619 Views)
