Remote panel image
Hello all.
I have LabVIEW 7.1.1, run-time engine7.1.1 and  IMAQ Vision 7.1.
May I see Image on remote panel?
Respect
 Aleksandr.
(3,543 Views)
Hi Aleksandr,
Each copy of LabVIEW comes with one remote front panel license which means that you can indeed monitor/control your front panel image remotely. Here are some articles that describe how to do it:
Ankita
(3,522 Views)
Thanks You for the answer.
But I have else question.
May I do the separate server remote panel that install it to another computer.
Another computer will be without LV.
Regards
Aleksandr
Message Edited by sasa14@inet.ua on 05-31-2006 06:57 AM
(3,509 Views)
I'm not sure I understand your question, but if you have the LV run-time engine and created an executable with remote support, then you do not need to have LV installed on the other PC.
JLV
(3,504 Views)
Thanks for the answer JLV.
May I don't install LV on host mashine. I want to do the (.exe) module and run it on any host mashine.
 Regards
Aleksandr
(3,500 Views)
You can create an executable if you have the appropriate LV package.
In the menu, look under Tools.  You should have "Build Application or Shared Library (DLL)".
JLV
(3,494 Views)
Dear JLV
Thanks for the help.
Regards
Aleksandr
(3,478 Views)
