Remote panel on cRIO with LV2023Q3 ?
i just switched to LV2023Q3, and opening a previous project with a cRIO target that uses a remote panel, i get the following error (with both 64 and 32bits version) when i try to create the html file with the web publishing tool :
Does the 2023Q3 doesn't support anymore the remote panel on cRIO targets ? If so (it would be a real issue for many users) what's the latest version that supports this feature ?
The strange thing is that the remote panel server is still present in the cRIO software list, and in the target properties.
Thanks for any help,
vincent
Vincent
(1,173 Views)
Hi again,
as a add-on, i've checked with another project, without any networked target, just a simple windows app. And even if the remote panel server is enabled in the option settings, i only get :
...so no more "control" option, just the snapshot and monitor.
I don't remember having such issue with the previous versions of LabVIEW.
Vincent
(1,127 Views)
Accepted by topic author VdG
Finally, i got the answer from another post "Web Publishing Tool - Missing Embedded View".
The remote panel died in 2022 😞
Vincent
(1,112 Views)
