Remote start of applications
Hi
I want to start Applications on other computers. I thought especially about starting a RDA, DataSocket or VISA Server remotely. I already suceeded in starting a new instance of LabView on an other computer via ActiveX Refnum with the Class LabView._Application. But as i tried to use other Classes in order to start other applications i failed. It just didnt work.
I attached my VI for starting LabView.
Thx for your Help
Michael
(2,847 Views)
Hi Michael
Here a two possible workarounds.
The easiest is to use the "system exec.vi" on your host PC. You have only to choose the working directory of the file on your target PC and to execute the command line.
Second:
1. Create a VI which has the "system exec.vi" included. This Vi execute system commands, e.g. calling a *.exe file.
2. Copy this VI to your target PC.
3. Call this VI with "VI Server" from your host PC.
Thsi should work with an executable too. (If no LV is installed)
Hope this helps.
Luca P.
Luca
(2,847 Views)
Hi
this sounds just like the thing i was looking for.
But i cant find a VI with the name "system exec.vi" on my computer.
Where can i find it?
Michael
(2,847 Views)
Hi
You'll find it in the "communication" subpalette. I don't know if this VI exists in each package of LV. I've the PDS package.
Luca P.
Luca
(2,847 Views)
