Yes, that's true.
The Citadel 5 historical trace data can be accessed through the Citadel 5 ODBC driver.
The Citadel 5 historical alarm and event data is stored in MS SQL Server (MSDE) and can be accessed through the Microsoft OLE DB Provider for SQL Server. However, the alarm and event mdb has three different tables (set, ack, clear) which need to be joined in a not easy way to have a nice view.
National Instruments would recommend to use the A&E ActiveX Control (Alert Browser) or the A&E query VIs.
Which application, development software are you using to build your remote client application?
Hope this helps
Roland
