Remotely interact with a RT VI front panel
Hi all!
Briefly, i developed a RT application on a cRIO with which the user interacts using a HOST application. So, nothing special, considering that the two applications have been developed in LabVIEW.
Now, in order to give more freedom to the user, i would like to allow him to interact with the RT application simply using a web browser. Reading this post, seems to be possible to publish the front panel of a VI through the web, but i don't understand if this can be done for a RT application. If it's possible, i ask to provide some suggestion on how to realize this.
Thanks!
aRCo
(2,670 Views)
Yes, you can do this, with some limitations. See the help for publishing RT target VIs to the web, this works for executables too. If you are trying to publish a subVI, make sure that in the build specification you do not remove the front panel (this is a change from the default behavior).
(2,637 Views)
